AlexHobson
Oct 24, 2024Aspirant
Slow speeds Orbi RBK763S with Virgin Hub 5
Hey Guys,
I am having trouble with speeds through Orbi RBK763S,
My setup is as follows:
In the house I have a Virgin Media Hub 5 upstairs that is hard wired into the Orbi with a Cat 6 cable, I then have 2 wireless satellites, one satellite is downstairs, the other satellite is in my music studio in the garden,
Previously I have had an older Orbi setup in the exact same way, same distance, everything the same, this was the Orbi RBR50 with two RBS50 satellites.
When I had the older Orbi installed, I was able to obtain speeds of around 400/500 down & 100 up in my music studio. However since 'Upgrading' to the RBK763S, i am only getting 100mbps download, and 60 up.
Does anyone have any ideas why this would be happening?
I tried using the Orbi in AP mode to see if this might help, but it was pretty much the same.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...What is the size of your home? Sq Ft?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?Any Wifi Neighbors near by? If so, how many?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageHas a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- AlexHobsonAspirantHey,
Thanks for your reply mate
So in terms of firmware, they are all on the latest update which is V6.3.8.5
Im not sure exactly the size of the house, but its a small 2 bed house on a terraced street, so as you can imagine there are quite a few networks surrounding
The distance between router and satellite is around 32 feet
I haven’t actually tried using the virgin router in modem mode, that will probably be my next test!
The only confusing thing is that it worked absolutely fine on my older RBR50 setup, i dont understand how the performance is so much worse on a newer system?- FURRYe38Guru - Experienced User
AlexHobson wrote:
Hey,
If you can get a size in sq ft, would be good to know this.
Try bringing all RBS to near or same room as the RBR and take note of the WLAN Backhaul speeds seen at the RBR.
Also try swapping RBS with each other to see if problem follows or remains at the remote location.
Definitely give this try as the ISP router has wifi built in and either needs to be disabled or ISP router but in to modem only mode.
- User763Aspirant
I also "upgraded" from the RBR/RBS50 to a RBR/RBS760 system last year in the hope of at least getting (security) software updates for a few years, but I must say it's not been a great experience. At least it works on my end though.
Make sure that the Orbi is really using a 1000 Mbps link speed to the modem. If you log in to the web interface, then under "Advanced" click "Show Statistics" you get a pop up that has the link status in the second column. On the WAN port, make sure it says 1000M/Full. If not, replace the cable. The next step I'd suggest is to disconnect/power off the satellites and make sure you get the expected WiFi speed from the RBR760.
- AlexHobsonAspirantHey mate
I get absolutely fine speeds when next to the Orbi router,
Its when i go into my studio the satellite is giving rubbish speeds
Just checked the admin settings and WAN is showing 1000m/full- FURRYe38Guru - Experienced User
WiFi Speeds will drop with distances of the RBS from the RBR. Nature of the beast.
Also this is just a dual band MESH system with not dedicated backhaul so performances will not be spectacular. The 50 series has a dedicated BH as other 750, 850 and 960 and beyond systems also have.
