tuxbox78's avatar
tuxbox78
(stability) problem with RBK853/its RBS850 satellites web interface
Hi, i have a strange problem with (only) one of my RBS850 satellites. One (and always just this same one) "looses" its web interface after a few days, but it seems its wifi still works as normal and the overview from the RBR850 router shows this "faulty" satellite works as usual and also has connected devices and a good backhaul connection. But when i try to access its web interface (no matter if the status.htm page or whatever) there is no connection possible to it.
A restart of the satellite solves it, but its difficult as it cannot be done remotely. Has anybody seen similiar behaviour or even a solution to it besided restarting the device every few days? Of course i got latest firmware installed, but i have this problem since the first days i got this set.
Thanks,
Frank
  • FURRYe38's avatar
    What Firmware version is currently loaded? Same version should be on both RBR and all RBSs.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    • tuxbox78's avatar
      tuxbox78
      Firmware Version V4.6.3.16 is currently installed (of course on both Router RBR850 and its two satellites RBS850). The Router acts in AP only mode and is connected to a switch ... i'm not sure if/what the internet provider could have to do with the satellites lan internal web interface. But if you want to know.. its german provider 1&1  (united internet) with a avm fritzbox 7590 to connect to it. But as said... neither internet nor wifi access has any problems. It's just the satellites web interface thats not reacting until restart after a few days...
      Connection between satellites and router ist always classified (blue) as 5G and good. The home has about 1200 sq.ft. and the positions of the router and satellites build a equilateral triangle with  each 36 feet distance to each other.
  • I am having the same problem.  The web interface will not load on one of my RBS850 satellites.  When I try to login to the satellite via a web browser, it asks me for the the username and password, but then nothing happens when I press the "Sign In" button.  Also, when I load the web interface for the Router, it sees the Satellite but shows it as "Out of Sync."  And when I go to the firmware update page in the Router interface, it states "Service Unavailable" for the faulty Satellite.  When I try to update the firmware from the router web interface, it is also unable to logon to the Satellite to complete the update. I did a hard reset and it did not solve my problem.  I was hoping that re-installing the current FW version on the Satellite would work, but I cannot access Satellite to perform the update.
    I am on the current FW version 4.6.3.16 for router and satellites.
    The satellite seems to be working, but I cannot logon onto it or update it.
    • FURRYe38's avatar
      What happens if you factory reset the RBS and connect it to the RBR via ethernet. Give it 5 minutes, then you should be able to log in to the RBS using a PC and web browser.
      • dcraig's avatar
        dcraig
        Guide
        Thanks FURRYe38.  I was able to get things back to normal by doing another hard reset of the Satellite and then syncing to router wirelessly.  Everything synced up and is working normally via wired and wireless backhaul.  I guess the second reset is what it needed.
