Bigpopman
Jun 05, 2022Aspirant
Starlink rectangle dish with a Ethernet adapter works with earlier Orbi products
Any luck with this? My Starlink rectangle dish with a Ethernet adapter works with earlier Orbi products, but not the 960. Should I return the 960’s or is there a solution?
What newer Orbi’s work with Starlink?
Something I got from NG support. Would be interesting to know if the suggestion worked.
I would contact StarLink and see if there modems are compatible with external routers.
Ask if there is any special configurations, i.e. DHCP or PPPoE or VLAN configurations that are needed.
For ISP modems with built in routers:
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop - CrimpOnGuru - Experienced User
Could you be more specific about how the 960 "does not work" with Starlink?
These folks seem fairly pleased with the Starlink Ethernet adapter:
https://www.youtube.com/watch?v=gBd7QmzPRGs They promise other videos discussing Bypass mode.
There's a article about setting up Asus routers for Bypass mode with Starlink:
- BigpopmanAspirant
Sure. I am using the Starlink ethernet adapter for the rectangle dish (V2) - works fine -n both regular Starlink with WiFi on and in and in bypass mode with the Starlink WiFi off.
The same Starlink ethernet adapter works fine with Orbi RBR20 - in both regular Starlink with WiFi on and in and in bypass mode with the Starlink WiFi off.
The 960 does not get internet access from Starlink, in any configuration I have tried. That's what I mean by "does not work".
BTY, I tried using the same Orbi 960 with my ViaSat modem, and that worked well. The 960 refuses to see any internet from Starlink V2.
- KshupeniaInitiate
It’s a stupid hack - but one that Netgear had me try when I first got my 960 last Nov with AT&T.
I put a 4 port switch in between the starlink router and the Orbi 960 router. Boom. All of a sudden it sees the internet.
Worked 8 months ago with AT&T - Then netgear sent me beta code to install and I was able to remove the switch - now that I switch to Starlink I saw the same thing. - so putting the switch back solved my issue.
I would Ike to now put the starlink in bypass mode and eliminate the double NAT - but for now everything is working and I don’t want to mess it up.,
