savagebeast's avatar
savagebeast
Swapping out RBR850 for RBR40
All; I currently have a RBR850 with three satelittes and an Arris S33 router (about a year old).  Xfinity have replaced the line and still around 3-4 times a day my internet connection drops (both in wifi or wired to one of the satelittes).  Question I have is I have a spare RBR40 - can that be swapped out for the RBR850 to see if that is the issue - is it essentially creating a new Mesh network and have to re-pair all the satelittes to it too?
Thanks SB
  • FURRYe38's avatar
    Does front LED on the RBR850 turn PINK when this happens?
    Does this happen with the RBS turned OFF?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    What channel configurations are currently set on the router?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
    Press the back reset button for 15 seconds then release.
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
    • savagebeast's avatar
      savagebeast
      Does the top ring on the RBR850 turn PINK when this happens? Not that I have seen; its two floors away however.
      Does this happen with the RBS turned OFF? No all of my satelites are on.
      What Firmware version is currently loaded? #sv4.6.14.3_2.3.12
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Arris S33 DOCSIS 3.1
      Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.  Yep
      What is the size of your home? Sq Ft? s2800 sq ft
      What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected. 40-50 sq ft
      What channel configurations are currently set on the router?   Not sure how to check
      Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update? Yep
      Has a factory reset and setup from scratch been performed since last FW update? no given the effort and worried i am not sure if its the Arris or Orbi system
      • FURRYe38's avatar
        savagebeast wrote:
        Does the front LED on the RBR850 turn PINK when this happens? Not that I have seen; its two floors away however.
        Turn OFF the RBS and see if this happens with only the RBR online.
        This version is not valid for a RBR50 or 40 series RBR. Please confirm the FW version or the RBR model#.
        For this size of home, a RBR and just one RBS is only needed.
        Look at the RBRs web page under Basic Tab/Wireless settings.
        What channels are you using?
        Would need to try this as last resort.
  • FURRYe38's avatar
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2 first...
