sbatchik's avatar
Jun 23, 2023
T Mobile Wifi calling issues
Upgraded from Nighthawk RAE500 6E router because of new home. Using the new Orbi 6E Mesh system. On T mobile. Wifi calling worked great before the switch but now it is intermediate at best. Most times, people cant hear me. Someone said you need to open ports on the system. Does anyone know which ports need to be open?
TIA
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Enable SIP ALG on the RBR and try.
    Also review this as well:
    https://www.surveymonkey.com/r/G32BGFF
  • FURRYe38's avatar
    Any progress on this?
    TIA
    • F_V's avatar
      F_V
      Luminary
      WiFi calling ports are 500 and 4500. I had the same problem, opening both of those allowed WiFi calling to work perfectly on both Android and iPhone.
      • FURRYe38's avatar
        I would try and enable SIP ALG on the RBR. It's disabled by default. Been testing with it enabled along with some others. Working with it enabled.
  • schumaku's avatar
    schumaku
    WiFi Calling does (and must) work without any port forwarding (how should it - considering there can be >250 LAN clients?) or any kind of SIP ALG.
    To get some ideas what in involved, here is what T-Mobile (US) does unveil e.g. for business firewall deployments: Wi-Fi Calling on a corporate network
    • F_V's avatar
      F_V
      Luminary
      I agree with you that it SHOULD work without port forwarding, but I just tested it by disabling my firewall rules for ports 500 and 4500, and WiFi calling fails.  As soon as I reenable the rule on those ports, my phones can make a connection on those ports and it works again.  To be clear I'm using a dedicated firewall, not some settings within the Orbi.
      • schumaku's avatar
        schumaku
        F_V wrote:
        ... I just tested it by disabling my firewall rules for ports 500 and 4500, and WiFi calling fails.  As soon as I reenable the rule on those ports, my phones can make a connection on those ports and it works again.  To be clear I'm using a dedicated firewall, not some settings within the Orbi.
        Great - so it's not the Orbi system in our case!
        Off topic then: Whatever unknown firewall (or other Internet security garbage on the end point) you might have in place, some have default policies blocking virtually everything, including IPsec - IKE Authentication (udp, port 500) and IPsec NAT traversal handling Encrypted voice traffic (udp, port 4500), in both directions, incoming and outgoing.
        That all does not help the OP, unless sbatchik does also operate an in-band firewall device, or some "block everything" default end point security.
