H-L
Aug 03, 2026Tutor
The phone keeps telling me the wifi is poor quality and switching back to mobile data
I have The same issue with my Google Pixel android phone. The phone keeps telling me the wifi is poor quality and switching back to mobile data, even though the wifi strength is showing strong on t...
Aug 03, 2026Guru - Experienced User
Does this happen only the Google phone?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Do you have the 6Ghz network enabled on the RBR?
What OS is on the phone? Be sure it's up to date.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
H-L
Aug 11, 2026Tutor
Haven't checked iPhone, so far just Google phone but I'm noticing peripherals like printer, web cameras seem to be dropping Internet but that may be unrelated.
4600 sq ft, 2 floors
Satellites are separated >>30 feet haven't measured all the distances. Edges of house have 2 hops to router.
Channel config is default - I'm an end user not a network expert
6Ghz network doesn't seem to be enabled. Phone and most devices are 5ghz.
No Wi-Fi neighbors near.
Os is fully up to date - Android
Mac address randomizers??? No idea.
- StephenBAug 11, 2026Guru - Experienced User
https://support.apple.com/en-us/102509
https://help.sfasu.edu/TDClient/2027/Portal/KB/Article/134150/Disabling-Random-MAC-Addressing-on-Android-Smart-Phones
Do the phones support 6 ghz?
Satellites are separated >>30 feet haven't measured all the distances. Edges of house have 2 hops to router.One possibility is that the backhaul wifi that connects the satellites to the router might not have a solid connection. Honestly, the backhaul status reported in the app and web ui isn't that useful.
One good way to check for that is to turn off the satellites, and then measure the wifi speed with your phone at the satellite locations. Use the free ookla (speedtest.net) app on the phone, and disable mobile data while testing.
In your case, start with the satellite locations that directly connect to the router. Then turn on the satellite(s) that act as a relay, and measure at the satellite locations that are daisy-chained. If performance is poor, you should look more closely at the satellite locations (again, testing speed with all satellites off), and see if there are better spots. Ideally you'd want to eliminate the daisy-chain.
Another path (which will give you better performance) is to install cat 6a cable to the satellite locations, and connect them to the router using ethernet. If you don't have enough LAN ports on the router, you could also get a small multigig ethernet switch.
- H-LAug 11, 2026Tutor
Phones Do support 6ghz but devices they connect to do not and I wanted them on same network. 6ghz seems to want to be another side, like iot.
Web interface shows backhauls are good.
Internet speed tests are showing ~500mb/s.
It seems to me to be sticky connection to satellites, with slow handoff between satellites as I move around the house.
If I go through the check you want what am I looking for? It's a long time gathering information - I need to know specially what I am looking for.
At the end of the day it's a consumer product and I expect it to work as advertised. As I said, it seemed to be fine for the first year or two. It doesn't look like it is a problem unique to me and I don't see resolution on the other cases. I was hoping it was a known issue with a known fix.
Orbi's main network should have 2.4, 5, and 6 ghz radios on the same SSID.
- FURRYe38Aug 11, 2026Guru - Experienced User
Try using manual channels 1 and 40 and 69 on the RBR.
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Your behind on FW updates:
New - Orbi RBK750/850/860/960 Series Firmware Version 7.2.8.5 Released | NETGEAR Communities
I've ran this version of FW months back and saw no issues like your seeing.
If you choose to update FW, follow this guide:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
