Barry1m
May 05, 2021Initiate
Turn off SSID broadcast - CBR750/RBS750
How do I turn off SSID broadcast on the CBR750/RBS750? There does not seem to be an entry on any of the (Basic or Advanced) wireless menus.
CrimpOn
May 05, 2021Guru - Experienced User
Barry1m wrote:How do I turn off SSID broadcast on the CBR750/RBS750?
Can you share the reason for wanting to turn off SSID broadcast?
- Barry1mMay 05, 2021Initiate
I like to have a 'hidden' network for security.
- CrimpOnMay 05, 2021Guru - Experienced User
Barry1m wrote:I like to have a 'hidden' network for security.
Looks like Orbi may not be what you need. Although, if a serious hacker wanted to bother you, it appears that not broadcasting SSID is a trivial problem:
- FURRYe38May 05, 2021Guru - Experienced User
Ya, Hidden networks are still easily found. Any wifi scanner can see them. Been like that for years.
Something thats not supported on Orbi AX systems.
