ae6dx00's avatar
ae6dx00
Guide
Feb 06, 2021
unable to access web interface or orbi app
I have remote access enabled on my Orbi. I can ping its IP address ands connect via VPN. but both thew web interface and app refuse to connect. Devices on the network are getting an internet connection. This just started today. RBK853 AX6000
  • What Firmware version is currently loaded?
  • I was able to fix this by just power cycling the main router. Did not have to reset or power cycle the satellite
  • I have this exact issue occurring with my AX6000 units. For some odd reason, periodically I will not be able to access my system via the app "issues connecting to #wifi' and the router GUI via 127.0.0.1 is unresponsive. Manual reset of the main router will correct the issue, but issue will occur again. A factory reset does not resolve permanently.
    3x AX6000 running the latest firmware, new issue.
    • The RBRs web page is located at 192.168.1.1 by default no 127.0.0.1.
      What FW version are you using?
      • s3v3n's avatar
        s3v3n
        Tutor
        Blah, I meant 192.168.1.1; not 127.0.0.1. Sorry for the mistake, late night.
        Firmware is 3.2.18.1 on router and satellite units.
        Network equipment is Netgear CM1100 modem aggregation linked to the AX6000 unit. DHCP is disabled on the router as I maintain a Pihole for the DHCP and DNS.
        ISP is Comcast with gigabit, 1000/35
