John--B
Apr 19, 2025Star
Updated firmware to 7.2.7.15 on a RBR750 and 2 RBS750's
I now have one of my RBS750's reporting as model RBS750QV and reporting that the status "update failed". Current name and current firmware version are correct and show firmware as 7.2.7.15 and three devices are currently connected to the RBS750QV. Anyone know what is wrong?
I updated my devices a couple of days ago to firmware 7.2.8.5 and all devices are working fine. Satellites are named correctly as RBS750. New firmware has corrected this issue. Thank you!
- SquuiidyAspirant
I'm seeing the exact same issue too. Identical; same number of units, same firmware same issue on one of them.
You'll need to make contact with NG support and let them know about this. Nothing else we can do here in the forums.
Revert the system back to what was working and disable auto update for now.
Someone else reported seeing this on there 750 series. How was the system updated? Manually or Auto update or Update ALL?
RBS should have been updated first manually then the RBR lastly.
Updating was done manually with the satellites completed before the router.
Does this V appear the RBS web page itself?
Does this appear on the RBRs web page under the connected devices page?
Did you load the FW thru the RBS web page?
Which web browser did you use?
That is so cool. (Mainly because there appears to be no such Netgear product number.)
Could you please post a screen shot showing this information.
Hopefully you can read this.
