flyingdutchgeek
Jul 30, 2025Tutor
Using Wired Backhaul, the internet is slow and jittering
 I have similar problem with RBSE960. Using Wired Backhaul, the internet is slow and jittering. On the Orbi Router portal is says Backhaul status = Good     When i unplug the cable and Backhaul via 5 ...
Aug 05, 2025Guru - Experienced User
Ah my bad. MBP is Mac Book Pro for me. Mbps is Megabytes per second.
What devices are you connecting to the RBS and seeing this slow and jittering when v.15 FW is loaded? Brand and model please.
flyingdutchgeek
Aug 05, 2025Tutor
Any device...
Android phones, Google TV, HP Notebook (Windows 11)
- FURRYe38Aug 05, 2025Guru - Experienced UserI noticed you did a factory reset on the RBS, did you do a factory reset on the RBR as well when you had v.15 loaded? This would have needed to be done as well to help check for continued issues. I use this all the time when doing a FR and setup from scratch: Orbi Systems Manual Factory Reset Process | NETGEAR Communities
