artiprod
Apr 06, 2022Aspirant
Virgin Router 4 and Orbi Mesh 6 system
Hi
I have Virgin 1gig Broadband and Virgin Router 4
I purchased an Orbi Duel Band Mesh WiFi 6 system RBK353
The VM Router has been put into Modem only status.
I have filled the instructions from the Orbi App to the letter, or so I think.
Evert thing goes fine until the final check .... all cables fine but no internet.
I have done the installation 3 times and each time the dreaded red cross on No internet.
I do not know what I am missing or how this can be rectified.
I am 70+ and a tech Luddite so please anybody able to help?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- artiprodAspirant
thank you for your reply, i will do as you suggest tomorrow and report on the result.
