Jazz_LFC
Feb 12, 2026Follower
What is Compatible?
I have a NETGEAR - ORBI AX4200 MESH WIFI6 2 PACK.
I need to get an add on however this current model is no longer available. What can I get that is compatible?
I need to get an add on however this current model is no longer available. What can I get that is compatible?The compatibility list is here:
Note that AX4200 is the performance/speed rating, not the model. It sounds like you have the Orbi 750 - you can confirm by looking on the router for the model label (RBR750). This should also be in the web ui.
If you do have the 750, then you can still find some new RBS750 satellites for sale.
Purchasing used is another option.
There's a guide that tells you what is compatible. If you can't find any in stock, renewed or used systems can be bought and the satellites paired with your old system.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
