UARK's avatar
UARK
What recommended cable modem for AX4200
I am wondering which cable modem that you all recommended for AX4200 mesh wifi system (cbale provider is COX). Welcome and appriacate for any suggestions. Thanks
Note: looking for DOCSIS3.1 with Gogablast
  • plemans's avatar
    Netgear makes several devices that are Docsis 3.1 capable.
    CM1000
    CM1100
    CM1200
    CM2000
    It all comes down to what you want. I wouldn't recommend the cm1200 just because it has 4x ethernet ports (cost extra for) and for most users, they can't use them. Reason why is that unless you have business class line or pay for multiple public ip address, you can only connect 1 device to the modem. Meaning the other ethernet ports are pointless. Both the cm1100 and cm1200 support port aggregation so ports 1 & 2 are useful if you're using that. but again, if you don't pay for the extra or have business class, ports 3/4 dont' do you any good.
    • UARK's avatar
      UARK
      Thanks for the recomenedation.
      I was thinking netgear CAX80, but it is unbelievable expensive. So, I think CM1100 is a good alterative choice.
      By the way, CM2000 has not coming out yet, right? The official website said this product will be available around 9/24. So, I guess this is a new product, right?
      • plemans's avatar
        The CAX80 is a modem/router combo device.
        the CM2000 has been released, it just sold out quickly. The CM2000 has a 2.5G ethernet port on it instead of using link aggregation like the cm1100 and cm1200.
