araghava's avatar
Jul 10, 2020
Wired Back haul and 3rd band
Quick question:
If I use a wired backhaul for my satellites, will the dedicated 3rd backhaul band then be used for regular data flow.
  • plemans's avatar
    Sadly, no.
    I've been wishing for that since orbi came out.
  • FURRYe38's avatar
    The wireless backhaul is there for when the wired backhaul gets disconnected or goes down. Nothng that can be user configured. Sorry.
    • araghava's avatar
      araghava
      Star
      Thanks for the response. I'm not looking for user configuration. However I would have hoped that the wireless backhaul could have been used automatically for regular bandwidth when the wired backhaul is working.
      • FURRYe38's avatar
        It's sits idle until it's needed. Same with 1st gen Orbi AC systems.
