Jul 26, 2025Guru - Experienced User
Anyone using the AT&T BGW620-700 gateway?
Looking for any users that has an AT&T BGW620-700 gateway in their environment with Orbi BE system attached.
Looking for feedback and experiences.
Thank you.
Ely
Jul 22, 2026Luminary
I recently upgraded to 5Gig Internet from AT&T, and the installer who came to do the upgrade installed this modem. I have been using it for about 2 months now with my RBE971 and one Orbi satellite. So far, I haven't noticed any issues. Orbi router is working as the router with the BGW620-700 in Passthrough mode.
- WRSORBIAug 04, 2026Luminary
Would you have Speedtest results using the routers’ based Speedtest for comparison? I also have ATT 5Gig service as well and started seeing the RBE971 drop from ~5200 gbps to ~4700 gbps download. The BGW620-700 is constant ~5200 gbps down and up.
