Jul 26, 2025Guru - Experienced User
Anyone using the AT&T BGW620-700 gateway?
Looking for any users that has an AT&T BGW620-700 gateway in their environment with Orbi BE system attached.
Looking for feedback and experiences.
Thank you.
Jul 23, 2026Guru - Experienced User
Is Protection Enging enabled or disabled on the RBR?
What is this CAT7 cable? UTP or STP?
Try CAT6A or CAT8 STP?
Brand and model# Ethernet NIC in PC?
Are you speed testing with Ooklas speed test app on the Ethernet PC?
WRSORBI
Jul 23, 2026Luminary
Protection Engine off. Cat 7 STP. REALTEK PCIe 5G. Only testing with Ookla in the routers.
- FURRYe38Jul 25, 2026Guru - Experienced User
Please test with Ooklas installable speed test app on a ethernet connected PC as well.
Be sure that the Realtek adapter drivers are up to date from the chipset mfr as well.
- WRSORBIJul 25, 2026Luminary
Tested with PC installed Ookla app, direct connect to router, latest Realtek driver:
