gte534j's avatar
gte534j
Attached Devices list shows for about a day then is not available on web app for RBE871
Hi,
The Attached Devices list shows for about a day then is not available on web app for RBE871. I do a reboot then the attached devices show again for about a day.
Router RBE871 V10.5.20.4_1.3.5
Satellite1    RBE870       V10.5.20.4
Satellite2    RBE870    V10.5.20.4
Satellite3    RBE770       V10.5.20.3
Any suggestions on how to fix this or is this just a firmware bug?
Everything else works great - i get great internet all around/outside the house. Its just the attached device list issue-
Thanks!
  • I have downloaded the basic debug log and the log file data but cant attached or share it for some reason. Is there something in the files that i should search for or find?
  • StephenB's avatar
    I see that with my own 870 - though with my system it takes longer for the problem to surface.  Like you the only way I've found to fix it is to reboot.  Which is quite annoying.
    I did try reporting the issue, but so far just crickets...
    I'm not seeing this at the moment, and I guess it's possible that the 10.5.20.4 has changed the behavior.
  • So below is what i see when i first reset the route- it shows the correct number of devices.
    Then about 6 hours later it shows this below.
    And then when i click on "attached devices" it gives me the "Please wait a moment"
    I am using the latest version of Chrome browser.
    Thanks!
    • FURRYe38's avatar
      Does same thing happen on MS Edge for Firefox?
      On same version of FW and Number of SATs and devices is howing correctly for me using MS Edge just now.
      I had seen this on prior version of FW. Since updating to v.4 and factory reset after update and setup from scratch, I haven't seen this issue again.
  • FURRYe38's avatar
    Same thing seen in the Orbi app?
    What is not available on the web page? Is the page blank or is there some error message?
    What browser are you using? Same thing happens in MS Edge or Firefox browsers?
    Happens with a different PC to compare?
    I have my 870 series online as well. Haven't seen this to date.
    • gte534j's avatar
      gte534j
      The orbi app shows 13 devices instead of 37. it does show the 3 satelites.
      When i click on the website "attached devices" it just goes to "Please wait a moment..." and nothing ever appears.
      This happens on Chrome and Edge browser on this PC and another PC Chrome.
      I did a factory reset as well and the problem still happened.
      Do you think its a hardware issue maybe? is there something in the logs that could help? Maybe one of my wifi devices is causing this problem?
      Thanks so much for your help and trouble shooting!
      • FURRYe38's avatar
        I don't believe this is a HW issue. Rather some odd behavior in FW. This is the only system model I saw this with. Though could be on the 770 series as well, nobody else has mentioned seeing this issue, other than us 3. My system has been online for just about 20 days now.
        This one maybe hard to troubleshoot.
        How was your system FW updated on the RBS and RBR? Automatically or manually by using a PC and web browser?
