MitchLittle
Oct 28, 2024Aspirant
CM3000 and Sparklight
Can I replace my current Sparklight modem with a CM3000 and full Orbi970 system and keep all of the SSID and passwords the same as my current system so that I do not have to update all of the endpoints
Yes.
I'm on SL as well and currently have my CM3000 connected to my 970 series system.
Be sure to check with the ISP as well on any additional requirements that you may have. If you have phone for voice support then the CM3000 won't work. Otherwise, will be fine to use. You can use same SSID name and password from current system on the Orbi system.
- MitchLittleAspirant
do you disconnect the old modem, then power up the new one before you call SL tech?
Yes.
