eric3312
Oct 06, 2025Aspirant
Firmware update sequence - should I be worried?
hello. Thank you in advance for taking the time to read my notes and help me I really appreciate it. I purchased the Orbi 770 series mesh system, 3-pack. I hooked up the router, following the...
eric3312
Oct 07, 2025Aspirant
Thank you for replying.
is it best to do firmware upgrades through the web interface? If so, does it at least give you an indication than it completed successfully too?
Oct 07, 2025Guru - Experienced User
I recommend using this process to manually update orbi systems: Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
