chmnda's avatar
chmnda
Guide
Jun 03, 2025
I Finally found a solution to fixing the ORBI970 iPhone WIFI disconnecting issue
I had frequent Wi-Fi disconnection issues with my iPhone on the Orbi 970, and after some trial and error, here are the steps I took to resolve it:
Adjust Wireless Channels and Security Settings
 Go to: Advanced > Setup > Wireless Setup
Change 2.4GHz Channel from "Auto" to "6"
Change 5GHz Channel to a lower channel like "36"
Change Security Options to "WPA3-Personal only"
(Note: WPA2-PSK or WPA2/WPA3 mixed mode may cause instability with some iPhones)
Click Apply
Optimize Advanced Wireless Settings
 Go to: Advanced > Advanced Setup > Wireless Settings
Uncheck "20/40 MHz Coexistence"
Under 2.4GHz Advanced Wireless Settings, change Preamble Mode to "Long Preamble"
Under 5GHz Advanced Wireless Settings, change Preamble Mode to "Long Preamble"
Click Apply
Check Satellite Sync and Connection Type
 Go to: Basic > Attached Devices
Ensure each connected satellite shows:
Status: "Good"
Connection Type: "5GHz" or "5GHz + 6GHz"
If your satellite is connected via 2.4GHz, it may cause poor performance and Wi-Fi drops
If needed, re-sync the satellite or move it closer to the main router
  • FURRYe38's avatar
    Maybe a good solution for newer Apple Iphones, however setting Security to WPA3 only will cause all other non supporting WPA3 devices, to not work on the main WLAN.
    Does those Advanced Setup configuration settings work with mixed mode WPA2 and WPA3 enabled or do you still see odd problems with the iphones?
    • chmnda's avatar
      chmnda
      Guide
      so far, no wifi connection are dropping for the iPhones 15 and 16 in my household.
      • FURRYe38's avatar
