VINE0001
Sep 22, 2025Aspirant
I manually updated to 10.5.20.3 on my 770
I manually updated to 10.5.20.3 on my 770, and after the update was not able to access some websites via a Mac running MS Edge. Strange that using Safari I could access those sites, but not with Edg...
donawalt
Sep 23, 2025Hero - Experienced User
VINE0001 first, IPv6 is VERY flaky right now. If you don't need it, disable it. NG has acknowledged this and is working on it.
Second - if you want to test it some just for fun, I know that Edge (Chromium) is more “aggressive” about using IPv6 (and HTTP/3/QUIC + DoH) than Safari. So Edge keeps trying the broken IPv6 route and doesn’t fall back cleanly, while Safari usually drops to IPv4 quickly and the sites load.
Here's how it happens, possibly:
• Different DNS paths: Edge may be using Secure DNS (DoH) directly to a provider over IPv6. If that IPv6 path is broken, name lookups fail for Edge, while Safari uses the macOS/system resolver over plain DNS (often IPv4) and succeeds.
• Fallback behavior: Safari tends to fall back to IPv4 faster. Chromium will often “stick” to a v6 AAAA it resolved and not pivot as quickly if the v6 connect stalls.
- there is also the potential that Edge jumps to QUIC faster than Safari, with the same result of getting hung as it locks there. - QUIC is an optimized network transport layer protocol that browsers jump to, again Edge might be getting hung there.
A few things you could play around with on one computer: (I am on Edge beta, these should be right based your version)
1. Edge → use system DNS (or turn off DoH)
edge://settings/privacy → “Use secure DNS” Off, or set Use current service provider (not a fixed provider).
Then:
• edge://net-internals/#dns → Clear host cache
• edge://net-internals/#sockets → Flush socket pools
2. Disable QUIC (temporarily)
edge://flags/#enable-quic → Disabled → relaunch Edge → try apple.com, wsj.com, microsoft.com.
3. Per-site data wipe (for the failing sites)
edge://settings/siteData → search apple.com / wsj.com / microsoft.com → Remove.
Do these one at a time and test.
VINE0001
Sep 23, 2025Aspirant
Thanks for the suggestions. After more troubleshooting, the router defaults to auto detect for IPv6. If, after disabling IPv6, and re-enable it, and select Auto Detect, it auto selects 6to4. This is when it fails. If I select Auto Config as opposed to Auto Detect, it works. Not sure exactly what that is doing as I am not greatly experienced with IPv6. From what I can tell, I don't think my ISP actually supports IPv6 yet, so not sure I even need to worry about having IPv6 turned on.
It is confusing as to why it would work on the old firmware as opposed to the new firmware. That tells me Netgear changed something in their IPv6 handling.
When I get more time I will try your suggestions, and also install Chrome to see if that works.
- FURRYe38Sep 23, 2025Guru - Experienced User
Who is your ISP and what is the brand and model # of the ONT your using?
Ya if you know that your ISP doesn't officially support native IPv6, then keep it disabled on the RBR. Mine doesn't and I don't have it enabled.
You could try Hurricane Electrics IPv6 service if you think you wanna check it out:
Hurricane Electric guide to enable IPv6 6rd on NG router | NETGEAR Communities
