kiyong
Feb 22, 2026Follower
I need 220v power supply for RBE362
I bought the U.S version of the RBE362 model, and it came with a 110v adapter.
However, I need a 220V adapter.
Could you tell me how i can purchase a 220V adapter compatible with the RBE362?
You can use whatever adapter you want as long as the output voltage and polarity are EXACTLY the same. You can have higher amps but not lower.
You face several issues:
- 110v vs 220v. Sometimes, Netgear has used multi-voltage power supplies and simply put a 110v label on them for the US market. The only way to tell would be a potentially costly experiment.
- Physical plug. The US style plug is different from electrical plugs used in other countries.
- The power connection must match the factory connector in size and polarity.
Using appliances manufactured for the US in other countries is a common situation. It might be worth considering a combination voltage/plug converter appropriate for your location.
