TOPS119
Nov 07, 2025Virtuoso
Is the new firmware working or not
I had issues downloading the new firmware 9.13.2.1 for the RBE 970 has a question sign on the file after download did they release a fix for this or is it the same old version being circulated with t...
- Nov 08, 2025
I did the update on the main Router which is the 791 and the other satellites auto updated. Thats different and new .
avalynn
Nov 08, 2025Tutor
It looks like there was an issue with the Netgear firmware 9.13.2.1 for the Orbi RBE 970/971 series: the download package contained the old version instead of the proper updated firmware
Nov 08, 2025Guru - Experienced User
All that was corrected and FW packages with in the .zip file are correct now:
New - RBE970 / RBE971 Firmware Version 9.13.2.1 Released | NETGEAR Communities
- TOPS119Nov 08, 2025Virtuoso
Did you do the update ? as I just tried and get error same way with thee files
