superglide71's avatar
superglide71
Follower
Oct 18, 2025
larger coverage Area
Does Orbi allow to add more satellite to existing mesh, If so witch units will except this process.
or can you join 2 mesh systems with same IP.
What is the most distance out doors can most receive, I have a 5 unit now but have very thick exterior walls
and it struggles to keep up.
  • StephenB's avatar
    Is this the only problem you want to solve?
    If so, is there a particular location where you need outdoor wifi (detached garage, shed, etc)?  Or is it a broader area (perhaps needed for security cameras???).
    It would be useful to understand the goals.  It's possible that more orbi satellites might not be the right approach.
  • CrimpOn's avatar
    CrimpOn
    Netgear claims that the WiFi7 system can support more than 4 satellites:
    https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
    They recommend that no more than 4 of the satellites use WiFi for their router connection, and that additional satellites be 'wired' to the router (connected with Ethernet cable).
    As for coverage outdoors, one test would be to temporarily locate a satellite in a window. Then go outside, walk around and observe the signal strength at various distances.50-60 ft. is probably a good estimate.
    It might be helpful to be more specific about the goal.
