orbifan1
Aug 29, 2025Follower
MLO Backhaul (Daisy/Star topography)- Wifi7 - Orbi 970/870/770/330
With your Wifi 7 range of Mesh Wifi Systems, in a set-up with more than 1 satellite , will MLO Backhaul work with those Satellites NOT directly connected to the Router? i.e for those satellites in a Daisy chain wifi set up topography.
1 Reply
As long as wifi conditions are good, MLO will be supported in Star or Daisy Chain formation.
Depending on placement for Daisy Chaing and how you turn ON the RBS, nears RBS to the RBR first, then following up with next farther RBS, should see Daisy Chain.
