kfeige000
Dec 16, 2025Aspirant
More Printer Problems with an RBE371 Mesh Network
I've been having a problem with my new Netgear Orbi RBE371 mesh network since I installed it on Saturday. I have two printers, an Epson ET-8500 and a Brother MFC-L3770CDW. Until Saturday I was using ...
kfeige000
Dec 17, 2025Aspirant
Thanks Furrye38. I haven’t tried this yet. My question is then do all the other devices like my laptop and iPad need to connect to the IoT network in order to print?
Dec 17, 2025Guru - Experienced User
No. There is open traffic between the IoT and main WLAN and LAN networks. Is intended this way so IoT supporting apps used on mobile devices connected on the main WLAN or LAN can communicate with there devices on the IoT network.
Also some older devices that don't support WPA3 security mode may not handle this being seen on the signal. Been a known issue for a while now. So using the IoT network you have the option to set only WPA2. If your printers support ethernet connections, ethernet would be recommended.
- kfeige000Dec 17, 2025Aspirant
Ah, okay. I will give that a try. Thank you!
