kfeige000
Dec 16, 2025Aspirant
More Printer Problems with an RBE371 Mesh Network
I've been having a problem with my new Netgear Orbi RBE371 mesh network since I installed it on Saturday. I have two printers, an Epson ET-8500 and a Brother MFC-L3770CDW. Until Saturday I was using ...
- Dec 26, 2025
regarding my statement: "this is the equivalent of "Private Wi-Fi address = OFF", which is very safe and reliable on Netgear networks as you have found on your other computers."
You had written that "The "Private WiFi Address" option doesn't appear in the network settings .....This seems to be the switch that works"
My particular comment meant that if for the reasons I previously stated, the Private WiFu Address feature is not available/does not show as a setting on your MacBook Air, you still have a situation that "works" - If available, Private WiFi Address set to OFF fixes your issue. I am saying that in computers that do not have that feature, they function like Private WiFi Address is off - meaning, there is no masking, changing, rotating the MAC address the computer reports. So the behavior of your laptop without that setting is identical to a computer with Private WiF Address=Off. You don't have to do anything.
kfeige000
Dec 20, 2025Aspirant
So far, turning Private WiFi Address off and putting the prints in the IoT network has seemed to work. It seems that both are needed because trying them individually did not fix the issue. Still testing, though, as there were a couple of times that the printers weren’t found. Thanks!
