Keara
Jun 12, 2025Aspirant
My iPhone 16 Pro and new iPad Air constantly drop Wi-Fi
Same issue here—started around mid-April. My iPhone 16 Pro and new iPad Air constantly drop Wi-Fi, while older iPads and my PC stay rock solid. Tons of IoT devices too, all unaffected.
Tried the usual fixes—reset network, turn off Private Wi-Fi, tweak Wi-Fi 6E, reboot everything—nothing works. I'm going to test with the satellite off and try the 2.4GHz IoT network next. Starting to think this is a bug between Apple’s new devices and Orbi.
Hoping for a fix soon. You're definitely not alone.
Can you try what is suggested here and see if this changes anything for you? https://community.netgear.com/discussions/en-home-orbi-be/i-finally-found-a-solution-to-fixing-the-orbi970-iphone-wifi-disconnecting-issue/2458460
