TOPS119's avatar
TOPS119
Apprentice
Jan 15, 2025
My ORBI 970 HAVING DEAD SPOTS
I have noticed that my orbi 970 even though showing almost full signal/bars has low internet speeds in some area of the house..Anybody else experience this? im running the latest firmware I have a 3 pack and also the house is only 2300sqft. I have used all the firmware and still have the same issue what could be causing this I've used multiple devices same thing and yes im connected hard wired and cat 6a
  • For that size of home, the RBR and just one RBS is needed. Placed out at 30 feet or a bit more from the RBR.
    Can you turn OFF 1 RBS for now?
    What channels are you using on the RBR?
    More information would be helpful, such as:
    • What device (or devices) have low performance in that specific location?
    • What is "low"?
    • Does the device itself display advanced information about the WiFi connection?
      (such as the "Link Rate" and which frequency band?)
    • What Link Rate does the Orbi 'app' display for these devices when in that location?
    • Is there anything unusual about that location?  (stone walls? lots of large metallic objects?
    • Are there other devices which show normal speed in that location?
    • Do the affected devices perform normally when in other locations?
    • TOPS119's avatar
      TOPS119
      Apprentice
      I surely answered these questions in the statement above.. Now for which channel each device is using I have no clue the router is in the room below as its a upstairs building and there is another one in the room beside this is wall building fully walled...But what I wanna know is why would it show almost full signal and not getting the speed. Ive used a laptop and a phone so multiple devices as mentioned before.
      • TOPS119's avatar
        TOPS119
        Apprentice
        So 2.4 is set to auto and 5ghz is set to 40, If thats what your asking..
  • What do you consider slow speeds?
    What actual speeds does it get? Is it all the time?
    Is it in the same spots?
    When its slow, check your device to see if its on the 2.4ghz, 5ghz, or 6ghz. The device allows bandsteering and the 2.4ghz is a slow band. So if you're device happens to be on 2.4ghz when you're testing, it will be slow. But if its on the 5/6ghz, then its worth investigating more.
    • TOPS119's avatar
      TOPS119
      Apprentice
      And funny enough I've never seen something on the 6ghz band my router only shows 2.4ghz and 5ghz am I suppose to be seeing 6ghz based on the fact I even have a wifi 7 phone and a Mac book capable of 6ghz ? They only connect to 5ghz
      • FURRYe38's avatar
        Guru
        If you have any 6Ghz supporting devices, they should connect to the 6Ghz signal first thing when near the RBR or RBS.
        Might turn OFF the RBS for temporarily and test each device while near the RBR. Check the RBRs web page for connection status.
