SuperMario22922
Aug 26, 2026Aspirant
NAT loopback fails for clients connected through RBE370 satellite
I’m using an Orbi RBE371 router with an RBE370 satellite, and I’ve found what looks like a NAT loopbackNAT issue. NAT loopback works normally when a device is connected directly to the main route...
HappyCat
Aug 26, 2026Luminary
Does NAT loopback fail if you use the IP address of the router rather than the URL?
- SuperMario22922Aug 26, 2026Aspirant
Yes it doesn't work with either the public IP or the URL
