SuperMario22922
Aug 26, 2026Aspirant
NAT loopback fails for clients connected through RBE370 satellite
I’m using an Orbi RBE371 router with an RBE370 satellite, and I’ve found what looks like a NAT loopbackNAT issue. NAT loopback works normally when a device is connected directly to the main route...
Aug 27, 2026Guru - Experienced User
SuperMario22922 wrote:For example:
curl https://example.ddns.net:8000
times out when connected through the satellite, but works through the router.
The hostname correctly resolves to my WAN IP, and I tested multiple forwarded ports with the same result.
Sounds like that should work. I am wondering you've tried:
- disabling ipv6 in the client PC
- testing with a port that isn't forwarded
That might give some clues.
Is there a particular service you need to get to work? FTP with passive ports comes to mind. But if that is the issue, you could potentially work around it by switching the to FileZilla client.
- SuperMario22922Aug 27, 2026Aspirant
I don't have IPV6 at all and i tried multiple forwarded ports and none of them work on the satellite
- StephenBAug 27, 2026Guru - Experienced User
How about a port that isn't forwarded? That should normally work locally, but fail when remote.
A port that isn't forwarded wouldn't work with the public IP or ddns anyway though? i'm sorry am i misunderstanding something?
I have a few web services that are port forwarded and i can't access them locally because NAT loopback is not working
