SuperMario22922
Aug 26, 2026Aspirant
NAT loopback fails for clients connected through RBE370 satellite
I’m using an Orbi RBE371 router with an RBE370 satellite, and I’ve found what looks like a NAT loopbackNAT issue. NAT loopback works normally when a device is connected directly to the main route...
SuperMario22922
Aug 27, 2026Aspirant
I don't have IPV6 at all and i tried multiple forwarded ports and none of them work on the satellite
Aug 27, 2026Guru - Experienced User
SuperMario22922 wrote:i tried multiple forwarded ports and none of them work on the satellite
How about a port that isn't forwarded? That should normally work locally, but fail when remote.
- SuperMario22922Aug 27, 2026Aspirant
A port that isn't forwarded wouldn't work with the public IP or ddns anyway though? i'm sorry am i misunderstanding something?
- StephenBAug 27, 2026Guru - Experienced User
I get that you need it to work on a forwarded port. I was thinking you could also test an unforwarded port (just to see if port forwarding was part of the problem). But that can't work because the router isn't listening on the destination port. So my bad.
One other question - are you testing using the 370 wifi network? Or are some of the tests using the LAN? When I have a chance, I can try this on my 870 - hopefully other Orbi users can also try it on their systems.
