SuperMario22922
Aug 26, 2026Aspirant
NAT loopback fails for clients connected through RBE370 satellite
I’m using an Orbi RBE371 router with an RBE370 satellite, and I’ve found what looks like a NAT loopbackNAT issue. NAT loopback works normally when a device is connected directly to the main route...
SuperMario22922
Aug 27, 2026Aspirant
A port that isn't forwarded wouldn't work with the public IP or ddns anyway though? i'm sorry am i misunderstanding something?
Aug 27, 2026Guru - Experienced User
SuperMario22922 wrote:A port that isn't forwarded wouldn't work with the public IP or ddns anyway though? i'm sorry am i misunderstanding something?
I get that you need it to work on a forwarded port. I was thinking you could also test an unforwarded port (just to see if port forwarding was part of the problem). But that can't work because the router isn't listening on the destination port. So my bad.
One other question - are you testing using the 370 wifi network? Or are some of the tests using the LAN? When I have a chance, I can try this on my 870 - hopefully other Orbi users can also try it on their systems.
- SuperMario22922Aug 27, 2026Aspirant
Yeah its the 370 series (RBE370 satellite and RBE371 router). So connected to the satellite the LAN of that service will work but the WAN so the public ip will not work. On the router everything works
- StephenBAug 28, 2026Guru - Experienced User
Just to clarify - are you connecting to the satellite LAN port, or to the satellite wifi (or have you tried both)?
- SuperMario22922Aug 29, 2026Aspirant
Yeah i've tried both. Satellite ethernet doesn't work and also satellite wifi doesn't work
