SuperMario22922
Aug 26, 2026Aspirant
NAT loopback fails for clients connected through RBE370 satellite
I’m using an Orbi RBE371 router with an RBE370 satellite, and I’ve found what looks like a NAT loopbackNAT issue. NAT loopback works normally when a device is connected directly to the main route...
SuperMario22922
Aug 27, 2026Aspirant
Yeah its the 370 series (RBE370 satellite and RBE371 router). So connected to the satellite the LAN of that service will work but the WAN so the public ip will not work. On the router everything works
Aug 28, 2026Guru - Experienced User
SuperMario22922 wrote:So connected to the satellite the LAN of that service will work
Just to clarify - are you connecting to the satellite LAN port, or to the satellite wifi (or have you tried both)?
- SuperMario22922Aug 29, 2026Aspirant
Yeah i've tried both. Satellite ethernet doesn't work and also satellite wifi doesn't work
