JimS-CLT
Jul 19, 2025Aspirant
Nothing will connect to my Satellite
My house is a conundrum, but still.... I have a satellite (the only satellite) installed about 50 feet indoors from my router, hung on a wall with the official wall hanging bracket. It's connecte...
- Jul 20, 2025
Actually your not up to date on FW. There is one more recent FW avialble for the RBR and RBS here:
Orbi Firmware Releases | NETGEAR Communities
New - RBE770 / RBE771 Firmware Version 10.5.19.5 Released
I recommend updating the RBS first then RBR lastly.
Follow this on how to apply the FW manually:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
JimS-CLT
Jul 20, 2025Aspirant
Netgear says I'm up to date, but it's 10.5.18.xxx
RBE, Not RBR
Jul 20, 2025Guru - Experienced User
- JimS-CLTJul 20, 2025Aspirant
I don't believe it. Tech support guys are always telling me to check my firmware level, but this time, it worked perfectly. I just don't believe it.
Thank you so much!
Of course, since the sat was up and the router wasn't, most devices are now connected to the sat. That'll work itself out, I imagine. There are some devices connected to the router.
- FURRYe38Jul 20, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
