Giovanni_L
Jul 24, 2025Guide
Odd iPhone 16 behavior after Orbi 772 FW update
I received a new Orbi 772 system (with FW 10.5.18.3) about 3 weeks ago and the system appeared to be trouble-free until a few days ago, when I finally took the latest FW update (10.5.19.5). While mo...
Jul 26, 2025Guru - Experienced User
Yes Orbi only uses .chk files. The User manuals may need to be updated as .img was from 10+ years ago with older NG routers.
I use this all the time when manually updating Orbi systems:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
Giovanni_L
Jul 26, 2025Guide
@ FURRYe38 thanks for the procedure document. It was very useful, especially given that the User Manual is a bit out of date on the subject of FW updates.
I was able to re-install the old FW 10.5.18.3 in both satellite and router, and now I will do more testing with the iPhone 16.
- FURRYe38Jul 26, 2025Guru - Experienced User
Can disable Auto update to prevent any FW from happening automatically.
- Giovanni_LJul 26, 2025Guide
I already did at the very beginning. I like to be in control of what FW version I am using
