mbolo01
Jun 05, 2026Apprentice
Orbi 37x and Local Network Control Block (224.0.0/24) multicast
Dear all, I have an Orbi setup (RBE371 and 2x RBE370) that is causing me headaches with LAN multicast. One of my music application leverages multicast against 224.0.0.234 for node/companion ...
Jun 05, 2026Guru - Experienced User
Does everything work if all is connected to the RBR if RBS are turned OFF temporarily as a quick test?
How is the RBR configured for AP mode? Dynamic or Static IP address?
RBR connected to host router using it's WAN port?
Brand and model# of the host router the RBR is connected too?
For AP mode, ALL should be flowing thru the system with out being blocked. There maybe some configuration needed at the host router to help effect that.
Someting to contact the music application mfr about and see if there are any specific configurations needed there.
