pbokeefe1027
Aug 25, 2026Aspirant
Orbi 770 + ATT BGW620-700 IPV6
Does anybody have a working configuration that allows IPV6 to leave home and reach public internet?
ATT Gateway -> Home Network -> IPV6
IPv6: On
DHCPv6: On
DHCPv6 Prefix Delegation: On
Router Advertisement MTU: 1500
ATT Gateway -> Firewall -> IP Passthrough
Allocation Mode: Passthrough
Default Server Address: 192.168.1.64 (this is not editible)
Passthrough Mode: DHCPS-fixed (address will be handed to MAC address below)
Passthrough Fixed MAC Address (MAC of the ORBI)
ORBI -> Advanced -> IPv6
Internet Connection Type: Auto Config
WAN Address: 2600:1700:1398:1040:ca10:2fff:fe42:c97d/64
LAN Address: 2600:1700:1398:1040:ca10:2fff:fe42:c97d/64 (same)
LAN is set to use Auto Config for address assignment
My client has address of
IP address
10.168.168.119
IPv6 address
2600:1700:1398:104f:2abd:28c7:93c5:e48d
Maybe due to your gateway already being a router.
Try disabling IPv6 on the ATT router and leave IPv6 enabled on the RBR. Try using DHCP for IPv6.
Ask the ISP what mode you should use on the RBR.Try enabling IPv6 on the ATT router then change the RBR to AP mode.
- pbokeefe1027Aspirant
The gateway is in passthrough mode, so the Orbi holds the WAN address directly.
WAN and LAN using the same IPv6 /64 could the problem. The Orbi should receive a delegated IPv6 prefix for the LAN through DHCPv6-PD. You might check Orbi’s WAN/LAN IPv6 details and confirm that clients are getting a global IPv6 address plus a default gateway and DNS.
Try putting the RBR in AP mode and then check for IPv6 thru the system...
