Skrelaxy
Aug 14, 2025Tutor
Orbi 770 satellites do not show up on network map even after turning blue
Hi. I have an orbi 770 tri-and which 1 main router + 2 satellites. The main router is functioning well. But the satellites after syncing with the router and turning blue, it still does not show up on...
- Aug 14, 2025
12 feet is TOO close between the RBR and RBS. 30 feet distance is starting distance between the RBR and RBS.
Lets see if getting the system updated in FW as well:
New - RBE770 / RBE771 Firmware Version 10.5.19.5 Released | NETGEAR Communities
Update the RBS first, then RBR lastly:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
Skrelaxy
Aug 14, 2025Tutor
Hi. Currently rbs are connected wireless. The led does fully turn off after a minute of turning blue.
Current firmware edition is v10.5.10.10
Router is connected to a modem from Internet service provider. Currently satellite is placed 12 feet from router
- FURRYe38Aug 14, 2025Guru - Experienced User
