Skrelaxy
Aug 14, 2025Tutor
Orbi 770 satellites do not show up on network map even after turning blue
Hi. I have an orbi 770 tri-and which 1 main router + 2 satellites. The main router is functioning well. But the satellites after syncing with the router and turning blue, it still does not show up on...
- Aug 14, 2025
12 feet is TOO close between the RBR and RBS. 30 feet distance is starting distance between the RBR and RBS.
Lets see if getting the system updated in FW as well:
New - RBE770 / RBE771 Firmware Version 10.5.19.5 Released | NETGEAR Communities
Update the RBS first, then RBR lastly:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
Aug 14, 2025Guru - Experienced User
Are you looking in the app or through the browser?
I'd highly recommend looking at the attached devices list through the browser. I've found that more accurate than the app
