eric3312
Jan 19, 2026Aspirant
Orbi 770 Satellites Randomly Disable All Radios and Drop Clients
I’m posting this to document a serious defect in the Orbi 770 series and to express growing frustration after months of dealing with it. I have an Orbi 770 system (RBE770 satellites, firmware V10...
CrimpOn
Jan 19, 2026Guru - Experienced User
Does the Attached Devices display accurately report where devices are connected?
Does a WiFi Analyzer program, such as WiFi Info View (Windows) or one of the Analyzer apps for Android indicate that those BSIDs are no longer broadcasting?
- eric3312Jan 19, 2026Aspirant
I am unsure what you mean. I will try to answer though.
The attached devices appear to be accurate, as the disabled satellite shows “No Devices Connected”, which makes sense.
I posted screenshots but maybe they got removed.
2nd, I believe you meant BSSID? If so, I have not tried an app yet to see if that’s the case. It definitely appears as though it’s the case.
no devices connected, radios show as disabled and gray in the satellite web UI, etc. I know, not definitive…if you have a good app to use for iOS, I’m happy to test.
