eric3312
Jan 19, 2026Aspirant
Orbi 770 Satellites Randomly Disable All Radios and Drop Clients
I’m posting this to document a serious defect in the Orbi 770 series and to express growing frustration after months of dealing with it. I have an Orbi 770 system (RBE770 satellites, firmware V10...
CrimpOn
Jan 19, 2026Guru - Experienced User
Thanks for responding. (sorry for the typo)
Yes, people are currently having problems when posting screen captures (or any type of image). Annoying.
The point of using a WiFi Analyzer application is to independently verify that the satellite radios are not broadcasting. If the router to satellite connections are showing as "Good", that seems to indicate that the backhaul channel is active. It would be interesting to know if the backhaul BSSID is broadcasting on certain channels and the user BSSID is not.
Is the case still open with Netgear? Might ask about another RMA
- FURRYe38Jan 19, 2026Guru - Experienced User
NG is already aware of this user.
- eric3312Jan 19, 2026Aspirant
Is already aware of this user or this issue? Also, can you elaborate?
User.
Though strikes be odd that you have had 3 new unopened boxes and all have exhibited this issue. Seems like something in your environment maybe causing issues, or but kind of doubltful that 3 new boxed units could be faulty. I have this same model and have had zero issue with it though mines a 1st gen edition.
Can you give some feedback to the questions I asked about please?
