eric3312
Jan 19, 2026Guide
Orbi 770 Satellites Randomly Disable All Radios and Drop Clients
I’m posting this to document a serious defect in the Orbi 770 series and to express growing frustration after months of dealing with it. I have an Orbi 770 system (RBE770 satellites, firmware V10...
Jan 19, 2026Guru - Experienced User
When you say you've had your 773 replaced multiple times and that your neighbor's 970 also exhibits the same behavior, it really piques my curiosity about your area. I've got an 773, an 873, and a 973 and haven't experienced any of this. When 1 device or package being bad is normal, 2 in a row is incredibly rare. But having 3 and then a neighbor with the same issue makes me think something in your area is broadcasting and causing issues/interference/blocking. Could be a random neighbor who picked up one of those cheap "wifi jammers' that used to be sold. Or something along those lines. Not sure but the odds of that many being bad is right up there with the lottery.
- eric3312Jan 21, 2026Guide
So, I did have Eero 7 Max setup in my house and NEVER experienced this issue....I returned it and opted for Orbi because suprisingly the range on the Orbi 770 series is better than Eero's most expensive option...so, more bang for the buck.
I had the Eero max for probably...2 months ...never had the issue...satellites (or whatever Eero calls them) always had devices connected to them.
Didn't return it - sold it to an old college buddy.
