Blairgowrie's avatar
Blairgowrie
Orbi 770 unstable
I have a relatively new 770 router and 2 satellites. It has become completely unstable, dropping satellites, dropping internet  connection to provider router. Simply stopping. I’ve rebooted, I’ve done factor reset and restart . It works for a couple of days then stops.
before I boot it out to the rubbish tip has anyone got any ideas
  • StephenB's avatar
    What firmware are you running?
    Is the backhaul wired or wireless?
    Are any multigig ethernet cables at least cat 6?
    • Blairgowrie's avatar
      Blairgowrie
      Backhaul is wireless. Ethernet cable from internet router is current. The satellites work for 24 hours os so and the just drop out . Rebooting and resetting takes forever and should just not be part of a mesh system requirement
  • plemans's avatar
    Before working on satellites, I'd focus on the router---gateway part.
    What modem/gateway do you have from your ISP?
    Turn off the satellites and just have the orbi router connected to the ISP's gaetway.
    Anything wired to that? Watch for stability. I always start with the first step in the process because its easy to blame the mesh but it won't work well without a stable connection.
    I've got the 770v1 and v2 and they've been incredible stable.
      Blairgowrie
      The isp router is a Arcadyan supplied by ISP
      wired to router is my security camera router
  • FURRYe38's avatar
    Size of home in sq feet?
    Distance between the RBR and RBS in feet? 30 feet is starting distance in between them.
    Channels being used on the RBR? Try 1 and 40 or 11 and 48?
