Mikeb17
Nov 06, 2023Aspirant
Orbi 970 & Xfinity Gateway
I just received my Orbi 970 Mesh WiFi System and hooked it up to my Xfinity Gateway (XFI ADVANCED GATEWAY (XB7)
I have the ethernet hooked up to the Mesh Router and then running into my computer, but my speeds actually dropped a bit.
When I was running ethernet from the gateway unto the computer my average speeds were:
1200 MBPS Download
35 MBPS Upload
Now with 970 it's dropped to:
950 MBPS Download
26 MBPS Upload
My speeds for WiFi are better, but was wondering if there's a better setup than just using the Xfinity Gateway.
My internet plan is 1200 down / 38 Up just for reference.
1200 MBPS Download
35 MBPS Upload
950 MBPS Download
26 MBPS Upload
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- Mikeb17AspirantI spoke to Xfinity last night about setting up the bridge and they said it was enabled, however when I check the 'Device Manager' on the app, it only shows 4 devices connected to it.
Will it only show devices that are directly connected to the Orbis Wi-Fi and not the other devices that are on the bridge from Xfinity?
How could I check to see if the bridge is working correctly on my end?- FURRYe38Guru - Experienced User
If it's actually in bridge mode, the RBR will have a public IP address that should look like ##.##.###.### and should not see a 192.x or 172 or a 10 IP address on the RBRs web page under Advanced Tab/Advanced/Internet secion.
- Dfran1Apprentice
Hi,
I have xfinity, some advice from me
NOTE: MY findings and opinion only!!
1. Never use cable supplied routers / modems
2. go to step one
LOL
I will (personally) never use rented devices from cable companies, I use the Netgear CM2000 cable modem and it is rock stable on xfinity, I have the..
1200 MBPS Download
25 MBPS UploadThey may have switched me to your upload speeds but I never see that so far...
Anyway when you rent routers / cable modems from cable companies they tend to have lots more control over your internet,
meaning..... they tend to limit speeds during high usage more , tend to have more little problems, poor wifi, etc....
hope this helps, I really find using your own cable modem and routers is best, at least for me.
