Jackpine's avatar
Jackpine
ORBI 971 DOESN'T CONNECT TO STARLINK
Has anyone successfully got the Model 971 to connect with Starlink? I recently purchased ORBI 971 at the recommendation of Netgear and it doesn't connect to our Starlink ISP. Have been working with Netgear support but no success so far. Very surprised it doesn't connect since Netgear has a tube video showing how easy it is to setup the 970 series to Starlink and a support tech assured me before the purchase that it would work. Based on the Community articles I used both Netgear and TP-Link switches previously with the 860 model before buying the 971 and neither approach worked. Been at this for a long time with both the 860 and 971 with no success.
  • Others have posted that using a non managed NG switch, i.e. GS-105 or maybe a GS-305 connected between the ISP adapter and RBR with out any other devices connected to this switch got the Orbi router working with this ISP adapter.
    Power OFF the ISP adapter/modem along with switch and Orbi router, then back ON starting with the ISP adapter/modem, switch, then Orbi router.
  • FURRYe38's avatar
    • Jackpine's avatar
      Jackpine
      Thanks for your reply. Coincidentally, Netgear Support, after exhausting all troubleshooting approaches, said yesterday that adding the NG GS-305 switch would  allow the ORBI RBE971 to connect to Starlink. So today, I bought an NG GS-105 switch, the store didn't have the GS-305, and it did the job.
      Another question - what range extender do you recommend for the 971? The distance to a second structure is 200 feet. I have one satellite and have yet to set it up so am premature asking this question however I'm anticipating it might not be enough. Thanks for your help.
