acmorton
Nov 17, 2025Aspirant
Orbi and Private Relay on iOS and MacOS
We are in the process of trying to upgrade from an older Orbi RBR50v2 setup to a new RBE371 wifi 7 system. The main reason is that Private Relay from iCloud+ stopped recently working and we have to t...
Nov 17, 2025Guru - Experienced User
Only items we suggest during off while at home is Private WiFi Address. https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
I been using Private Relay on my Orbi AX and BE systems with out issue.
What model phones do you have and what iOS is loaded on them?
- acmortonNov 17, 2025Aspirant
Hi, we're using iPhone 15 pros, all running iOS 26.0.1. We updated the BE system to the latest firmware 12.1.3.11. We don't have a modem on the house, just direct fiber from the ISP into the house and to the router. I'll check the article above. If anyone else has had this experience I'd like to hear how and if you resolved it. Thank you!
- FURRYe38Nov 17, 2025Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers ONT the NG router is connected too?
How does using Apple iCloud Private Relay affect NETGEAR Armor? - NETGEAR Support
