claeer
May 21, 2025Follower
ORBI R760R with one satellite
I have bought the ORBIRR760R less than 6 months ago to replace another ORbI with wife issues. A week ago it was in and out of the internet. My service provider spent then one hour and more with...
May 21, 2025Guru - Experienced User
Does the front LED on the RBR/RSX turn PINK when this happens?
What Firmware version is currently loaded on the RBR and RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
I hope that is a typo. We can't give help for "wife" issues.
