ChevDaJuiceman's avatar
Nov 29, 2025
ORBI RBE 971
Just purchased an ORBI 970 series from a reputable seller, item is not new it’s used but in amazing condition. Was tested by seller before being put up for sale. I purchased, but for whatever reason the light just keeps on blinking white. I’ve tried multiple factory resets, I even factory reset my ATT modem and still to no avail the router just won’t connect or finish the setup. It’s looking like I’ll have to return. There’s nothing else left to try, guessing it might be a firmware issue but I can’t even set it up to address that issue. Oh well
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
     Static IP Address Configuration for AP Mode | NETGEAR Communities
    https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
    • KevinLiT's avatar
      KevinLiT
      NETGEAR Moderator
      Hello ChevDaJuiceman ,
      Welcome to the NETGEAR Community!
      The pulsing white behavior indicates that the Orbi Mesh system is powering up, or the satellite is looking for the router. On the router (RBE971) there is a yellow port in the back that states " Internet 10G". The RBE970 only has ethernet ports. The satellite for the Orbi Mesh systems (RBE970) requires a Orbi Mesh router (RBE971) to function.
      Please see the knowledge based article below for additional details on the LED function of your RBE970:
      https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
      Best,
      Kevin
      NETGEAR Team
