Altaer
May 30, 2025Guide
Orbi RBE771 Latency issues every 60 minutes
Ever since purchasing RBE771 back in October of 2024, I have dealt with an issue where every 60 minutes exactly on the dot my internet has super high latency for 30-60 seconds, and then returns back ...
Altaer
Jul 15, 2025Guide
No, I am still dealing with the issue. I am hoping to install the new Orbi firmware update when it becomes available to me within the web interface and will report back if it fixes the issue or not
- FURRYe38Jul 15, 2025Guru - Experienced User
You have not updated the system manually yet?
- AltaerJul 15, 2025Guide
No, since I work from home and rely on internet for my job, I am hesitant to manually update firmware or try beta firmware.
I updated my 770 series using this process:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
Fairly easy to follow. Maybe something to try on the weekend off work hours.
Mines been stable on this version of FW.
